reset electric window procedure
yellowsub
+1 pulled the battery yesterday now the drivers windows only goes up bit by bit so it takes like 10 clicks to close the window put i can just hold down to take the window down fully. would the procedure be the same from legacy to impreza
Here ya go: Initialization of power window
If the vehicle’s battery is disconnected due
to situations such as battery or fuse
replacement, the following functions are
deactivated.
. One-touch auto up/down function
. Anti-entrapment function
Initialize the power window in the following
procedure to reactivate such functions.
1. Close the driver’s door.
2. Turn the ignition switch to the “ON”
position.
3. Open the driver’s side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely.
Note only use the non auto function of the switch for this
ie, 1/2 switch movement
The auto system will not reset otherwise
After reset auto function will work as per normal
 johnny5 said:
tried this one didnt work for me, pulling in the up direction will raise the window 20mm so it takes like 10 clicks or more to raise the window only happens in the up direction and no auto function at all as well
did you pull it ALL the way up or only far enough so the window goes up, as it does say to only pull it up to the first notch NOT to where it is for auto close
 We are borg']
First notch i originally had the half window problem then it morphed into my current problem might take it into winger i think
