Vf29 vs TD05
bad_gt
its mounted right were all the pipes merge (right next to RF Wheel) to plumb it i would need to run a pipe from the external to the down pipe..with that sayin it would run pretty close to the ground lol..and i gotta angle the s**t outta my car around speed bumps which suck lol..
If its welded on the pivot u can normaly use a thin cut off disk on a grinder and slice the weld in half so the actuator can still move - if the flap is welded u pretty much need a new housing - most cars these days with gates still have the actuator still there just disconnected
Internal flap is welded lol..sucks.
saw it when i changed my clutch today, had to take off downpipe..cant be bothered changing housing
just gonna keep it as is until i change my setup again..
im running 10 psi at the moment until i can get a tune..
im planning to run 14psi (safe setting or shortening the lifespan of the turbo lol)
