Idle surge
I have a 99 wrx wagon, put an external gate on it and have noticed a slight idle surge. It will sit on about 800RPM then drop down to about 500-600RPM then hop back up to 800RPM. Not really to sure what the problem may be. Thinking AFM maybe?
 madmike said:
Hang on...
You now edited your first post to say you put an external gate now and now it hunts...
Go back and check your work.
No, I edited my 1st post because I missed out putting a "n" on the end of then. Thanks.....
+1 for Idle control valve, the v5/6 ones get really bunged up, its the 6 pin round stepper motor that sticks out the top of your throttle body, I cleaned mine out with brake cleaner as it evaporates once it dries.
failing that maybe a vacuum leak
If cleaning the iacv fails to fix it I would look at 02 sensor -when O2 signal is poor the engine will hunt for idle as the air fuel ratio swings wildly
Can test O2 simply with a multimeter with a graph
One question- does high idle work when cold ?? Is idle at cold sid and smooth ? Does it only hunt for idle when hot ? Or hot and cold ?
If cold idle is fine but hot idle is hunting that points towards O2 sensor
When cold it idles sweet. I just cleaned the ilde control valve, It was a bloody pig sty! Has helped but seems to struggle a wee bit, taco needle doesnt move like before I cleaned valve. Might check oxygen sensor.
