Car Puter
joshhorn16
I dont know what section this should be under as there could be many.
I am In the process of building a lightweight in car computer. Primarly it will be designed to handle on screen gauges will upload pics in a day or so. Figured that i have the time and i am bored may as well do it :-)
  • Replies 60
duct tape ? nah jokes
are you thinking of mounting the screen into the dash or?
what do u want to show on the screen ? cos realistically when racing - only gauges u wanna see would be water temp - boost - oil pressure and temp - air fuel ratio and EGT - which the obd will only be able to supply water temp
edit * unless its ver 7+ obd2 - it can feed you water temp - boost and air fuel ratio
oh yes forgot about ver 5 being obd2
BUT - ver 7+ has a wideband air fuel sensor - and pretty sure ver 5 doesnt? maybe wrong tho but im pretty sure it only has a narrow band o2 sensor - which is no good for air fuel ratio display
 kwi_fozze said:
joshhorn16, what are you using to display your gauges in a v5 via obd2?? i'm hunting around for a program and for the life of me, i can't find one....
i use rom raider logger. it supports most subarus. tricky B*tch to set up but once you have done it 2 or 3 times it easy
http://www.romraider.com/RomRaider/Download
HEre is the link to get you started easiest option is to give the computer you are using internet when setting up
