hard start problem
Hi guys,
having a weird starting issue with my car lately, during starting, the car will keep on cranking but will not start, if it start it will stalls straight away like theres not enough fuel...always start when cranking second time but will idle very low for few second (misfiring) then suddenly to the normal cold starting rpm 1.5k to 2k rpm..(this will only happen when cold, once it starts up, its fine for the rest of the day, start first pop)
car is a nz new v9 sti, cant seems to figure out what is the problem, the car drive fine and boost fine, just first start in the morning... car doesnt throw any code...
was thinking of getting a obd scanner? (which i assume would cost an arm and a leg)
thanks
Its located in the cross pipe thats under the inlet manifold, can be accessed by removing the alternator. It'll have a 3 wire plug going to it. Yes a faulty temp sensor can cause hard starting when cold. It tells the ecu how cold the engine is and will richen up on cold starting. If its not getting the right signal it'll revert back to the normal hot running fuel curve, which is quite a bit leaner, hence why its hard to start when cold...
few things that need to be checked are
fuel pressure (does it hold rail pressure overnight?)
does it fire initially? in which case coolant and crank sensors OK (which would indicate mass air sensor fault)
Have had 2 V7's before with similar cold running issues, turned out to be coil packs
Has the cold temp alignment been tested of colant sensor
My old v3 STI did a similar thing except not when cold. It would normally start first pop in the morning but when you went to start it 4 hrs later, when i went home for lunch, it would turn over as normal, hiccup, then turn over and start.
It never got any worse the whole time I owned so I never worried. But i would stilll like to know what it was?
glow plugs... ;D
i tried again this morning, i let it have a longer crank, it did start but stalls immediately, then i tried the second time, it start up straight away, like i said, it only happen when it is cold... pretty weird problem though cars only travelled 35k, wouldnt expect coils to fails that quick?????
cheers
a small update, while i havent had the time to get around to check the stuff, i do found that for the last two days during cold start, the car can start after a few cranks but still sputter like want to die but will eventually come to life...
bad tank of gas???
bad afm?
cheers
have you started it today??? have you tried turning ign on then give it a short crank to start fuel pump and wait for it to prime then turn over to start? give that a try....
  • 3 months later...
small update... here regarding the problem
had been busy and away for the past few months
i've have disconnected the battery while i am away and when i am back
the car fired up first pop, first crank
but now the problem is slowly coming back
still figuring out what is the problem
there is no check engine light, the car is standard, everything is fine apart from starting it first thing in the morning
any ideas??
