well when the factory head unit is connected the aerial went up and down when you turn the key on and off, but I installed my pioneer and it doesn't do this any more . . so what i'm asking is what wire is the signal wire for the aerial?
did you use an adapter of hack the wires up
http://www.trademe.co.nz/motors/car-stereos/other/auction-513089561.htm
Most after-market equipment, including Sony, uses a standard color code:
Yellow: constant power
Red: switched power
Black: ground
Orange/white: illumination
Blue/white: amp remote turn-on
Blue: power antenna
Speakers: solid color is positive, black stripe is negative
Left front: white
Right front: gray
Left rear: green
Right rear: violet
