who has had success in running yellow injectors on a grey injector ecu?
scoobygt
they will run fine, but theres not point unless your ecu is tuned for it, my mates old v2 non sti ran them for 3 years before he sold it, your car will just run rich over the whole map and use more fuel but you wont get any extra power unless your running way too much boost and your old injectors were leaning out up top.
but its a pretty rangi way of trying to fix that problem.
if you used something like an SAFC2 you could make use of the bigger injectors however.
what is a SAFC2? people say twin turbos can't be tuned because there maps aren't very simple and the after market ecu's don't understand it or some thing? just trying to make it run abit richer so I don't run too lean and get knock, unless you know of a better way to do it and still be able to keep the greys? as in not spending to much money ect
