car wont idle ??
 wrx_lou said:
shouldnt need to if the clamps are tight. have you got your BOV hooked in right?
dunno bout the blow off either , i just sort of modified (squashed) the bit on the pipe where the bov goes and put (forced) the bov straight on to the pipe with no adapter(prob not good idea???)
that would be your problem. my bov came with an adapter to wield on. but it was stainless so i couldnt stick it on my alloy i/c pipes so what i did, was get a couple of inches of radiator hose and two clamps and use it as a joiner between the two. anyway you could do that?
yea i will give that ago tomorrow hopefully if i have time after work
a mate reknz he used silicone
did your mate use silicon sealant or spray to fit them? you know that silicon spray will turn to glass when it gets hot and cover your o2 sensor and fuk it aye... but automotive type silicon sealant is mostly sensor safe.
unsure what the bro used??
trying to avoid the silicone option as i dont want anything getting sucked into the piping which may cause another prob
if i was you id go over all of the joiners with a screwdriver and tighten them. and failing that get out the brake/carb cleaner and spray around and find a vacuum leak...
Be careful with brakleen and a running engine, things like stray ign sparks or the alternator can cause a fire
You have something MAJORLY WRONG, should be able to here an air leak that big
What else did you do? if it was running right before - 99.9% chance YOU have caused this issue :(
 crazymf said:
Sounds like you may have a major air leak or an air flow meter problem of some sort. Have you checked every join an plug to make sure its all connected properly?
in the process of doing this now,
  • 3 weeks later...
 sickmatesick said:
what was it mate
had a mad air leak on silicone joining turbo outlet & piping,
had another air leak on silicone joining the piping to the manifold inlet,
and had a split in the 90' bend 3 port turbo inlet hose.
fixed using leggy parts at a total cost of $20 at the wreckers
not bad i rekn
