Can anyone tell what the block is depending on...
reaperblitz
Can you tell what the bottom end is from the engine number on the front top of a block, under the intake manifold by the cam cover on the drivers side?
The following is the number S20C xxx?
Am trying to find details on a friends block I\'m about to Frankenstein.
Will pull inter cooler and all the other stuff off tonight to get to the back of the engine for the proper block numbers (if its there)
Also heads/cam cover wise, the cross hatching depict which engine heads?
And by looking at the inner of the heads themselves can you determine what cams they are running I.e version?
