Fitting aftermarket guard indicators GC/F8
Timmah
So I bought a set of aftermarket guard indicators for my car a while back off Trademe. They are very cheap and not the perfect fitment the seller said. However, I am posting to show some Kiwi ingenuity and how I managed to make them fit and stay.
The Problem
The silver clip in the photo is meant to go inwards when you\'re installing them, to give a little pressure and hold the indicator in the guard. However, I\'ve found that it\'s far too stiff and my attempts in adjusting it ended up with it breaking.
My solution
Unscrew the plastic clip from the stock indicator
And then screw it onto the aftermarket indicator.
Perfect!
Except they\'re now next to impossible to get off. But oh well!
Also, I\'ve had these on for a year now and have passed two warrants. I decided to remove them and do this mod after drying and applying silicone sealant in hopes to make them water tight.
  • 3 months later...
 sti555 said:
how do u remove the guard lights.do u need to remove the guard itself.cheers
Look atr the pics above, the light kind of slides back a bit to release that catch and then the front edge lifts out. Use your fingers not a screwdriver or you will damage your paint.
 Timmah']
The stock ones should pop right off with some wriggling. Don\'t be afraid to use a little muscle.
haha my muscles are having a little trouble getting them off.i have studied the picture above and am pulling from side to side.might have to destroy the factory ones to get them out,think vice grips and a tea towel will do the trick.cheers
