no spark
i have just put a new engine in my 92 wrx due to cooked motor...now im having problems...no spark in cylinders 4 and 5 and very weak erratic spark in cylinders 1 and 2...coils have tested up ok...plugs have tested up ok...please help as im ready to burn it
  • 4 weeks later...
when you replaced the engine, did you use crank sprocket and cam pulleys from your old engine or from the new one? if the new one is there than it would be worth swapping it with your old ones. some crank and cam pulleys have different marks for cam and crank sensors and will not be compatible with the ecu that is in the car.
