Remind me - how to read CEL codes, BG Legacy?
boon
I did search and just got all sorts of results about random CELs...
BG Legacy throwing a rather intermittent CEL.
Hooked up the 2 single-pin green connectors under the left side of the steering column, car just beeped at me when I turned the key to ON (???)
Isn\'t it supposed to flash some sort of code at me?
Do I need to un-hook the black single pin connector nearby or something like that?
I hope it has a code stored...
yea it aint the sharpest
searching vis Google might work better, put site:clubsub.org.nz at the end of your search string?
eg
Restrictive Searches Google also has restrictive searches that allow you to limit the sites or information that you are searching for.
[soccer site:whitehouse.gov] Will return only documents from the site whitehouse.gov with the word soccer on the page, in the title or in the anchor text that links to the page.
