idle issue v6 sti with link g4
Pappu1
when warm the car idles fine but when cold starts it hardly idles and keeps turning off
need to keep pressing accelerator to keep alive
have tried adjusting the throttle body but with varying results
seems to run semi ok with the idle solenoid unplugged
are there specific fields to check in the G4 tune for idle (just to rule out any tune issues )
have a feeling it could be the solenoid perhaps...
ok so got cold idle sorted (changed the enrichment values and the idle solenoid % openings a bit)
and adjusted the throttle return a bit to have a stable idle
but issue now is
once car is warm and after a bit of bosting when come to stop at the lights the idle goes up to 2000rpm and refuses to come down
blipping the throttle makes no difference
only restarting the engine gets it settling down to 1000 again
what to do next?
 Stoffa said:
Set your idle lower and adjust you warm up enrichment insted
u mean the target idle values to be lower in the warm coolant range yea/
its 800atm
warm up enrichment
hmm will look at that
lol the G4 is sooo different to the stock ecu lol (i prefer the romraider look of things somehow)
what are ur tables like?
i will try and post the values off mine once i grab the lappy from the car and can compare..
does anything else affect the warm idle on the G4?
Im running a v7 throttle body so my settings are no help.
Get it idling how you want it when its warm.
Then use the warm up enrichment to make it run richer when cold which should make it idle higher without changing the idle settings
i will try hehe sounds good tho
