"Stop Lamp" light on dash coming on
wildturkey
1989 RS leggy (BC5)..........whenever I turn on the headlights or spotlights I get this "stop lamp" sign lighting up in the top left hand side of the speedo dash. after 10 seconds or so it goes away. It started doing it at around the same time as one of my spotties started playing up so I replaced the bulbs in them and they are all sweet now.....but this stop lamp light still comes on when i turn either the spotties or the headlights on. Does any1 know what this is?
 BC5RA said:
Get somebody to stand behind you and see if your brake light's activate.
Did this start happening after your fixed your brake issue?
nah it was happening way before the brake prob but yeah I'll check out the brake lights for sure.
yeah on mine they had cut into the power feed for one of the brake lights and not soldered the connection or wrapped it so over time it corroded and intermittently tripped the blown bulb warning light
when i put my foot on the brakes......the stop lamp light goes out
it could be a normal taillight blown
I know that the parents calais has a wee light like this that when it is a blown stop light it only comes on when u press brake pedal....
but when it is a taillight it come on when the lights are turned on and goes out when brake pedal depressed...
next time it comes on stop and have a look at your taillights
Check your brake light bulbs. Actually pull them out, don't just get someone to see if they work from behind. I've had a Legacy with a blown bulb and the filament dropped onto the tail lamp filament, and every time you put your foot on the brake the dash backlights would come on. We were scratching our heads for a while there....
  • 2 months later...
I've got the same problem with my GC8 Rex, I checked the bulbs and swapped them round but the dash lights still come on when I brake.
Maybe I have a short somewhere? how do I check that???
I had a brand new bulb sitting around, which I put in and tested but still not working. Then I thought maybe both bulbs are blown. I had some old bulbs sitting in a workshop drawer which I started swapping around, but to no avail. I think I will buy another new bulb and go from there....
