clutch cover bolts
loner
So, my old clutch cover bolts look tired as, especially the spring washers on them... so before I
go into Subaru and get told I have to wait until Monday for some new ones from AK... does anyone
know where I can get some suitable bolts from... without waiting? and I don\'t mean going to a
general bolt shop and getting some that look like they\'ll do the job... In Welly... thanks
Not after second hand... just wondering if anyone knew of a shop that had specifically purposed bolts... BNT, Extreme etc...
I could just ask around, but I\'m short on time today and really really want to get the car back together in the weekend.
Go to a proper bolt shop (Steelmasters etc) not just a Mitre 10 or whatever - Tell them what you want the bolts for and specify what grade they need to be, they will be able to sort you out.
When we put clutches together that need new bolts we usually use grade 12.9 cap screws (M8 thread for subarus). Hope that helps.
So, what I have exactly is... Grade 12.9 cap screws, M8, 16mm long with a 1.25 mm thread pitch.
I have checked these against the original bolts and they match. I have some new spring washers
and some high strength loctite as well.
The "cap", which I didn\'t realise, means they are allen key bolts... so I\'m guessing
12 ft/lbs is about hand tight, and that the torque isn\'t too critical...
