Inlet manifolds
ARGHAYE
i have a v1 ra and i want to change to a vf22 turbo which means i need to change the manifold, whats the difference between a wrx and gtb manifold? look similar except the coil mount which doesnt matter as mines coil on plug anyway, is there anything else different between them? will use after market turbo inlet pipe aswell
a gtb one doesn\'t have the coil mount. v3/4 wrx or sti (red) have the coil mount
you could change to wasted spark tho as its a bit of an upgrade.
as for differences some of the gtb manifolds have smaller runners = less flow (not so important till you get up in the power scale)
If you do a split rail fuel system there will be enough room under the manifold for inlet. :D
Use a twin turbo manifold if you change it. ;) Plenty of room then, you can also fit a bigger intercooler as well. ;)
as the throttle body moves forward.
