what ej20 is this 02 loom from? also anyone have a third sun visor?
goose
Hi all, long time lurker and avid reader.
I recently bought a V7 STI wagon and ran a diagnosis using a bluetooth reader attached to my phone and it says the 02 sensor is fecked.
Tried ordering a new one from Armstrong but it doesn\'t fit the loom (outer plastic wont fit). Also tried finding the part number but the previous owner had spliced in a Toyota Denso unit. Anyone know what this loom is from? Im thinking its from V7+ as it has the white plastic seperator in the connector but could be wrong.
One that is attached to car and is working:
https://www.dropbox.com/s/wl4y80hrmvu0780/02%20sensor%20loom.jpg
Also, found this inbetween the two visors. Does anyone what it is?
https://www.dropbox.com/s/s8upuhvhjqjxmn0/2013-02-18%2021.04.48.jpg
EDIT: couldnt get the images to attach sorry, links posted instead
Shot guys, thought it might be a visor but couldnt figure why they would compromise weight for something of little value. Will give it a go next time im galavanting into a sunset.
Its a pre-turbo sensor (with the longer cord). The one I have from Armstrongs looks perfect but its got the wrong connector on it. Where did you source your sensor from milkenfee?
V7 owners, can someone check their sensor connector and if it is the same can you pm a chassis code so I can order it from that? Would help a ton!
