GTB Legacy - Check Light and Engine cutting
bmc
Hi all,
Drove my legacy home today all good.
I then get back in it to go for a drive a couple of hours later and I realise the engine check light is on. :-\
The car drives fine, but once you accelerate moderately with a little force, the car will start moving well and then reach a point when the engine or turbo cuts out like a surge or jolt. You can cruise along on the motor way or the streets fine, its when you apply a little bit of acceleration with very minor force this fault occurs.
Any ideas? - have never experienced this before. :(
Ok - have run the CEL codes, but have not re-set the ecu as yet.
I have:
23 - air flow sensor? - Open or Short . This one could be historic as it appears my air flow unit has been reconditioned sometime ago and also appears first.
66 - Sequential turbo system - No rise in pressure or pressure excessive (Over boost)
In english what does this mean?
afm is a very common fault, and code 66 is a mofo - can mean half a dozen things but none terminal
do you have a boost gauge - what is it running?
Code 66 is from boost falling outside of what is expected - either not making enough, or making too much, it can also pick up a fault in the tt switching bits as part of this - if its really low, it can pick up an air leak as a "turbo problem" too
Sorry,no boost gauge but would assume standard boost being run subject to this fault.
AFM fault - does this simply sound like I need a new AFM
Re 66 - I suppose I will just need to take it to a mechanic and hope he knows what he is doing. At least I won\'t be paying for a diagnostics check.
I am just hoping its not a blown turbo or something expensive. I have just spent over $2.5k getting my honda head being re-built as of last week due to a engine check light fault and running rough at idle.
To me it does sound like an AFM fault. Some people will go years without ever having one fault - one of my previous cars ate them regularly (did 3 in a year!) - the symptoms you are describing sound like normal AFM issues.
The code 66 could be related to this as well - it could well be "under boosting" due to bung AFM and triggering a code 66 as well.
Try AFM first, do an ECU reset (just whip the battery terminal off for a minute or three, or there\'s a way to do it with the diagnostic plugs - I\'m too gammy to bother with that) and clear both codes, some people will trigger a 66 every now and then and just do a reset to clear it. It\'s not the end of the world by any stretch, and is so vague that to be honest I wouldn\'t go paying someone to look into it unless it was a daily / weekly occurence.
Might not hurt to borrow a boost gauge just to check nothing untoward going on there though
