Secondaries keep popping in a rev d
94 Leone
So, met a couple with a rev d, which it keeps popping secondaries(their car actually blew the secondary for the 3rd time coming up the hope saddle) I know it will be something other than the secondary causing issues; something in the \'zaust or inlet? Anyone come accross something like this, they had said another time it blew on the desert road when they hit a bump(obviously something fell into it). They took it to subaru(not sure where), got it \'running fine\'.
Really interested into what may have caused this catastrophe.
lol . hit a bump and it blew a turbo . took it to the shop and they got it "running fine" ::)
have they actually replaced the turbo twice ?
think this car has a meat ware issue aswell .
how have you diagonoised blown seondary turbo ? no boost after 4.5k rpm but fine before ?
Yeah; They\'ve had it replaced twice in 2 weeks.
Losing power in fourth, though this time It\'s just smoking like s***, so probably more than just the secondary.
I haven\'t had a look; too dark, they\'ve got a mate coming to trailer it back to westport;
Just wondering if anyone\'s had these kinds of issues; with a rev d.
Running fine but considering the car blew again,obviously not.
Doesn\'t make sense to me either; They haven\'t had a look yet; could be primary; they assumed it was the secondary because that\'s what\'s popped recently.
I haven\'t had a look; Was just throwing something on here to see if anyone\'s had issues like this, with a rev d.
Need more info before even attempting to diagnose what the go is
Smoke generally a bad sign though
Secondary being dead will not cause power loss unless you\'re fanging it - in 4th would mean 150kph plus
Rev ds run the vf31/2 and 33, and are the least likely of all to die like the old ones do
Someone is being taken for a ride by the sounds of it
My secondary is nackered and I can blow air through it from inlet to downpipe, can do the same with an old ct20 turbo I\'ve got, a blocked oil return bango filter/mesh could be causing oil to flow straight into the downpipe causing the smoking? See if there\'s oil in the downpipe and excessive oil in the turbo to TMIC pipe?
you know turbos dont actually have seals a such . . if you looked inside one you wouldnt be surprised if you could blow air through it . how much air is another matter
Yeah I know, shouldn\'t happen. My CT20 with about 2mm shaft play I can almost breath through the shaft/bearing assembly. My current/fitted VF27 (201,000kms)I can seal the inlet put a compressor to it and hear air hissing out into the downpipe. My replacement VF27 (90,000kms) I can just, only just get air through it.
My only semi plausible explanation is worn out front and rear oil seals and undersized worn bearings, or maybe lack of oil in the floating bearing assembly or cracked housing???
