faulty oil pressure sensor / gauge
funkytown
faulty oil pressure sensor / gauge in my oil pressure system?
Its a greddy unit, with a sensor, and a control unit and electronic gauge. the sensor is a 3 wire item.
What happens: when you start the car randomly every few starts the gauge reads totally nothing. just blank. Car does ALWAYS have pressure.
most of the time it reads fine and is accurate, 3-4bar warm idle and 7bar hot in the revs.
Its doing my head in how to test or work out why it sometimes wont read anything. help working out what / where to test would be most useful.
The control unit has its power wires shared with the oil temp gauge which works fine seemingly.
ta in advance.
Ha ha!!! Solved. After much dileberation and learning to drive a multimeter i trwced the issue to one of the sensor wires that plug into the controller. It had lost its clip in tab, the bits that stop pins coming out of their plugs. So fixed and re pinned and now it sits properly in the plug and i am getting consistent oil pressure.
Winner.
