bc5 rs with tdo5 hesitation / coffing under boost
aaronbay
Hey guys I\'ve got a 89 rs legacy witch did have a vf8 on it but I got a tdo5 rebuilt
And put on and now once it gets to 4000rpm it losses heaps of power and gives a few
Miss under full throttle but once it gets to 5000rpm its fine, only does it when your foot
To the floor lol, could it be the knock sensor?
But... If its only seeing 12psi and then dropping to 10, the wastegate itself is proving capable of handling things just fine? (point being its not overboosting according to the gauge)
Unless I\'m missing something
Do these run an airflow cut or is it purely a psi based one?
I know my forester (v6) would airflow and boost cut, had it cut on me going down towards ruapehu 4 up and full of s**t at 12psi, boost cut is 14.5
It could very well be a MAF limit cut, the td05 can flow quite a bit of air....
Sent from my GT-I9300 using Tapatalk 2
  • 2 months later...
