Adjusties knock/thump
Just bolted in a used set of D2s. The left rear has a slight knock when you come off the gas or give it gas but sometimes on a straight flat piece of road it feels/sounds like youve run over a person but theres nothing on the road.
Possible shock problem being temperamental like that?
Springs seated fine and captive same height etc as other side which is fine. All bolts are tight and wheel nuts are too. Nothing else was changed when I swapped the struts in.
Will pull apart when I get the chance but everything seems tickety boo.
a. It\'s because they\'re D2s
b. It may be the pillowball in the top mount
c. If they\'re camber top mounts the mount may be loose
d. If they\'re adjustable rebound, the rebound damping may be set too aggressively
e. If you have them set up very firmly and they\'re not sagging much they may be "topping out"
Inclined towards a or b.
Awesome ride better than stock and super lows. Not camber mounts in the rear but are pillowball. Its just does it randomly I havent taken it for a big drive yet either but done it twice rolling round town say 20km or so.
D2s are all good had some in a car never had problems and a mate has some and been rolling on em for the last 5 years no problems so dont think quality is the issue but the rest of what Boon has said rings true
