2002 wrx loud whistle help
Ok done anothe leak test today also checked for exhaust leaks found nothing what is weird though is I done a oil change because the previous ower used castrol magnatec 10w40 so ive put In castrol edge 5w30 and noticed the noise only happens at 13psi now rather than 9-10psi uhmm now I suspect the turbo bearings may be at fault here think going to bite the bullet and get a new turbo and upgrade the y pipe. Anyone have any suggestions for where to find a aftermarket y pipe to fit a 02 wrx??
 kwi_fozze said:
while you are there, you may as well swap out the TMIC with an sti jobbie, and use the sti Y pipe, improvement over the stock item and 9 times out of 10 will cost less than just an aftermarket y pipe
Isnt the sti one considerably bigger so the shroud doesnt fit up proper which isnt a good thing. Jump on ebay and get a silicon y pipe or yip sti y pipe gives gains if the late non sti pipe is anything like the early y pipes.
