Cambelt gone? Worth repairing?
M_C
Love my Subie GTB. So much its the second I have owned. Till the day the music died...
Cruising down the motorway the engine died suddenly. Now just turns over fast as if there is no compression. Seems like typical of a cambelt failure? Bugga as car regularly serviced too.
I am guessing the engine is not worth repairing assuming the cambelt has gone as likley too much damage being an interferrence engine?
Can anyone suggest good source for another engine?
Or maybe have an engine for sale?
I am in AKL and have posted add in WTB section too.
Thanks!
Try a used belt, Pull it apart and put a used belt on, kick it in the guts and see if it runs as it should, if it does go shopping for new bits, if not find a replacement motor, It\'s not a huge amount of extra work and you will have to pull the radiator and other bits anyway either way.
If you were closer i\'d come and do it for you as i have a few used belts here, i\'m sure someone close to you has a belt you can use.
Also a useful note, If the motor is ok buy the belt and bits from either Partmaster or BNT, Here in CHCH they both supply genuine subaru hydraulic tensioners (as the aftermarket ones had issues) at less than trade from Subaru, The waterpumps are the same as genuine and the idlers are also just the same, main difference is a saving of about $200
 Eight dollar']
[quote name='jost said:
Seems odd that it didn\'t go at all, should have still started just sound like crap. Possibly something else causing it not to start also?
correct - it would have to have bent valves on ALL cylinders to not even run
And that you would have noticed, would have gone bang and locked up.
I\'d be double checking timing and checking for error codes.
Excuse my ignorance and please correct me for being wrong (I am dead keen to learn everything I can about these engines) but when the timing belt snaps or something similar like this case, does it not cause the pistons to hit the valves and bend them etc? Thus interference engine?
I also found this, just incase anyone else is interested http://www.scoobyenthusiast.com/subaru-faq/which-subaru-engines-are-interference-what-subaru-engines-are-non-interference
Looks like I was on the right track but not quite right.
99% of the time both DOHC NA and turbo version are perfectly fine
Yes they are interference but due to the design with 4 cams - the cams roll onto the back of the lobes when the belt breaks which leaves the valves shut
Evo\'s etc with only two cams - end up with 4 or more valves left open when the cams stop
