car dying on track
Cost vs benefits
A surge tank setup is a relatively cheap insurance (we\'re talking under $400ish for a simple setup) - same as a baffled sump is cheap insurance
Up to you if you want to chance it or not
(Also a buzzy external pump is total "because racecar" spec BTW)
I\'ve seen one done where it had a normal walbro (or whatever) *internal* pump mounted inside a seperate surge tank - quite clever I thought, very tidy way to do things and much less volume - factory pump fed surgey tank as per normal - in effect only difference in cost was just the cost of the tank and getting it mounted (which is eff all really)
Doesn\'t have to go in the boot - you can mount it undercar as well
It\'s one of those things which can be either an annoyance or a 1-off bad luck thing which costs you a 2k motor
You play the odds I guess - could spend 10k making an indestructible fuel and oiling setup just for the driver to be the faulty component and put the lot into a wall instead
 funkytown said:
you cant put a surge tank in the boot in a hatch :P so your point is not valid. lol.
(unless its sealed and thats really hard / $$ )
Nope the "natural customizer" did it with that perspex fish tank lol. But yea youre right. Still valid in a sedan though ;)
Anyway a sedan isnt exactly sealed between the cabin and boot.
 evowrx']
found it - surge tank tucked in there rear there on the drivers side :)
