puk clutch vs organic disc
bc5rs
im looking into a new clutch for my bc5 after it gets a tune ,using it for generall thrashing on the track as such ,can get a puk clutch with hd cover kit for 540+ same as grouop n he says which this guy noes his clutch data its scary sometimes, not worried about drivability because its eith in or out ill figure it out in between has anyone run into issues or ideas for or against either option please
puks are ok.. you can get good clamp from a full face organic if you have a good uprated pressure plate.
Puks tend to be rather on or off... and from what i\'ve seen about the place, particulary if you have a 5mt or an original RS 5mt.. they shatter gearsets if abused with heavy clutches.
depending on your power output a full face IMO with uprated pressure plate will do everything you need it to. putting a puk in from what i can read is not warranted.
Yeah i run a full face with uprated clamp on the race car, purely to not stress the gearbox\driveline more than necessary, clutch is a wear item so I\'m keeping it as the weakest point in the driveline. havent had an issue with the clutch yet but i\'m only launching 200ish kw
