Scarles HDi boost controllers
jimme18
some reading for an answer to the above question
http://www.clubsub.org.nz/forum/index.php/topic,35842.msg504156.html#new
AnwY they work fine if u set them up correctly
Prone to some slight overboost in cold temp
I had thT issue so simply set it up on a cold night and that way that was the maximum
It made less boost in the summer
if u Wana get something like that just get a hallman pro as it controlls better than that one and is more consistant and costs less
Win all around mate
thanks for that
So basically from that write up a cheap ebc will not use a solenoid to control boost.
Does that mean with a closed boost system u would have to use an external wastegate or is it still fine with a internal?
The unit I had had 1 knob which changed boost. No gain on it at all so gate still started opening at half pressure. No different to one of the boost tap with spring and ball in it in my mind. You set the boost level period. Cant turn a tap off though.
the scarles one doesnt reference manifold pressure (actual boost) against a preset level... (closed loop)
the manual controller and the scarles ebc are effectively like the 1.5 and 2.0 non turb impreza.
both do the job, ones a flashier more expensive version, just not as good as the sti...
(sti being $$$$ controler with closed loop referencing)
just as a comparative.
the closed loop controlers will allow you to preset a duty cycle, how rapidly it comes on boost, how sensitive the controler is to boost fluctuations... set a boost level as target, and it\'ll do its best to maintain that preset boost level come hell or high water.
Well thats what it says but like I said I raised boost with it but doesnt hold gate shut like closed loop does. It says it uses closed loop to stop fluctuations after level is reached?
http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-627625996.htm
By employing a unique closed loop boost regulating technique, the boost fluctuation is minimized once the desired boost level is reached.
Yeah the regulating of spikes is in the preset gain settings, either way the unit I had worked great and boost onset was better than a boost tap or stock solenoid.
If you ask me not a huge waste of money if the car doesn\'t need a big flash ebc?
$200 is a waste of money when a marky tap will do the same job or when you can get a decent secondhand ebc that will really work well for $200. This isnt just coz scarles are shit either lol. Mine was no better than a tap.
