Mongoose M60G install. BE5 revC
swanson-07
Be real careful about what you cut into. Adding the 10ft or so of wire up to the alarm brain and the resistance of the immobilizer relays themselves will f*ck up your sensor readings if you decide to cut them.
Without a pinout I couldn\'t tell you what to chop, but I reckon the car won\'t run too good if the crank angle sensor isn\'t present ;)
