Dashlights stay on without key and car wont fire
joshhorn16
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
checked the resistance. from what i can understand after doing a bit of reading if you were to connect a test light to the positive terminal of the connector going to the coil pack and the other end to one of the switch grounds the light should be on and then when you try turn it over it should blip off and on momentarily is this right ?
if this were to be the connector
____
positive terminal |+ -| negative terminal
switch ground 1 |- -| switch ground 2
if i connect the test light to \'postive terminal\' and \'negative terminal\' there is light on ignition and whilst cranking
if i connect the test light to \'postive terminal\' and \'switch ground 1\' there is light on ignition and whilst cranking
if i connect the test light to \'postive terminal\' and \'switch ground 2\' there is light on ignition and whilst cranking
Generally a test light is connected to earth so on the switched side you would have no light on til the ecu breaks the earth to spark then you will see light as the pulse :) (all with coil plugged in)
Don\'t think that\'s your issue have you tried checking spark at the spark plug ends of the ht leads like evowrx is saying?
On the coil side of the plug between positive and trigger 1 then positive and the HT tower of coil 1 and then between positive and trigger 2 and then positive and HT tower of coil 2
Very vague ranges as i\'m not sure exactly
1-5ohms primary winding (positive to trigger)
5k-15kohms secondary winding (positive to ht tower)
