Dashlights stay on without key and car wont fire
joshhorn16
Just finished all my the work required to get my car back up and running again and now i am struck with the problem of the car not starting (it cranks over) there is no spark at all also when i remove the key alll the dash lights stay on and i can operate the electrics excluding the radio. the things i have done to find the problem is try two other ecus as well as plug in an obd2 cable which only lights up but doesnt work when the key is removed. any ideas ??
  • Replies 57
further progression was it wasnt the knock sensor it was something else but in the process it had blowen the crank sensor so chucked a new one in and what do you know motor sparked coughed got my hopes up and then jump straight back to square one. so too find a new sensor.
 JoKer']
also what colour is your car?
[quote name='DacerX said:
are you trolling joker? next you will ask if he has tan interior
of course : my question was about as usefull as "my car has dash lights on" on a Subaru forum
could be 1 of about 30 makes/model variants across the Subaru range
without proper info we cant give proper answers no?
Year and Model for starters might help, details on the donor motor, is it even compatible etc, what ECU (you cant get CEL codes from a link the same way as a OEM Subaru ECU etc
and a solution for the dash light (even tho its been rectified) could be back-feeding via the loom if its got the wrong sensors in the wrong motor.... or the starter motor was wired in wrong givign +ve on all the time
