WRX RA manifold and ecu
smokn4
  • Replies 57
 BC5RA said:
W6 identifys it as a 1993/1994 WRX ECU with 11.4 psi
A 1994 WRX RA ECU should have the code W9 so i would imagine that possibly the 1993 WRX RA shares the same ECU as the WRX.
thats weird cos after putting it in i went for a boost round the block and got
9 psi-1st gear
11 psi-2nd
and 13 psi in 3rd
then eased into 4th
 BC5RA said:
+1
7K is STI mapped and found in 96/96 STI RA
It is a desirable ECU as it will also fit into Gen1 RS perhaps you could put it on Ebay OZ.
just what i wanted to hear lol, hmmm ebay you say, what would it be worth over there?
 driftrex']
[quote name='BC5RA said:
+1
does yours have boost/rev cut etc
 driftrex']
I've seen them go for $250 AUS
It's an OE ECU it will have an RPM/Boost cut.
yea it boost cuts at 18psi, i have tried it before, and the rev cut i cant remember what it is, kamineko told me when i bought it but i've never hit it so it must be quite high. used to always hit the standard wrx one.
 BC5RA said:
The 5th injector is dormant as far as i know. Its there for Group A and Group N homogolation purposes (for rally teams to easily utilise) when active i would think that it either ON or OFF not pulsed.
There should be a discernible difference going from a WRX ecu to an RA version; usually higher RPM and boost.
As far as the inlet is concerned there will be no performance gain there.
regarding inlet,
would it do any damage if i put it on??
even though prob no power gains??
would it just use more gas?
 smokn4']
regarding inlet,
effectively they are the same manifold so nothing would change. would be a waste of time unless you wana paint it up first to look nice.
You'll basically be swapping one manifold for an identical one.
It's yet to be proven the 5th injector runs.
If you haven't already you could setup the RA manifold for a split fuel rail and then swap them.
yea plan on doing that fuel rail mod.
so the 5th injector is basiclly just there for looks??
does not function at all??
WRX and WRX-RA do not share the same ecu. V2 RA's have a different head setup and rev higher. the 7K spoken about above would rev to 7800~7900 with little taper in boost and pulled well with a free flowing turbo back exhaust
i'm impressed that you had the car dynoed driftwrx :) something i never managed to do with that ecu
--- GC8 A WRX MT U8/W6 AA810
WRX AT V5 AB530
GF8 A WRX MT V9 AB750 *
WRX AT V5 AB530 *
Ver1 GC8 B WRX MT U8 AA810 * RJ2
WRX AT V5 AB530
WRX-RA MT SB 00070 RZ1
STI MT SA 00070 * RZ0
GF8 B WRX MT V9 *
WRX AT V5 AB530 *
STI MT SC 00110 RZ3
Ver2 GC8 C WRX MT Z4 AC121 * D17
WRX-RA MT Z5 AC131 * D18
STI MT 6K AC700 *
STI-RA MT 7K AC710 * D22 AFM: AA160
GF8 C WRX MT 3B AC281 * D19
WRX AT 4B AC291
 BC5RA said:
For Group A and N purposes.
In order to have certain tech available, it had to be introduced on the road going versions.
Kamineko, Driftrex i believe made that power through the rear wheels.
correct, also running td05 sti turbo, but had some restrictive factors, eg factory intake, factory tiny topmount, catylic convertor lol. all to be changed very soon tho.
WRX AT V5 AB530
WRX AT V5 AB530 *
WRX AT V5 AB530
GF8 B WRX MT V9 *
WRX AT V5 AB530 *
STI MT SC 00110 RZ3
STI MT 6K AC700 *
WRX AT 4B AC291
so according to this the ecu i have just gotten is a std gc8 ecu???
do the gc8 ecu have higher boost/rpm levels than the gf8 ecu??
as both mine (boost/rpm levels) have raised
it could be chipped, open it and have a look
exhaust mods will change your factory boost. most 'this ecu boosts xx psi' quotes are pretty irrelevant
 kamineko']
will check 2morro ,
how will i know if its chipped??
or will it be obvious once opened?
