Urgent request: Pics of GDB breather hose routing
boon
Hey guys,
I need to put all my breather hoses back to where they need to go.
There\'s not a lot of good pics on the net of the bit I\'m after so hoping some clubsubber can help me out.
I need pics of the hoses coming off the driver\'s side rocker cover and where they go to, particularly around the intake pipe and the crank breather down just in front of the turbo.
Alternatively, can anyone make some recommendations on how I can plumb this sucker up better?
Twisted, no AFM. STI so it has the large diameter pipe that seems to go between the 2 rocker covers and a port in the middle, and the smaller diameter that goes between the rocker covers, the tee-piece that comes off what I think is the larger crank case vent and the PCV valve on the bottom of the manifold.
No catch can.
oh haha you\'l have had those tacked into your old intake pipe right and PCV.
I welded my pcv shut and connect one set of head breathers and the crank case to the catch can, i have a second set of breathers on the heads which are just tee\'d together (they could be to to catch can as well).
nothing to intake, nothing to pcv, but can go to PCV if you wunt... just gana get oilies in your intake.
Take the oppo to BIN all the hard lines - they get all up in the way.
