Quick spool valve
Anyone on here played with this stuff? Seems easy enough to build yourself if you had a workshop and some actuators/adjustable aftermarket one to play with. Build it into the turbine housing or as an adaptor then just run it up on the dyno closed and open to figure out where you need the actuator set. $500usd for one is f*ck that territory.
 telemekas said:
The twinscroll turbine housing in this context is used as away of generating a smaller intial A/R on a big turbo.
Like a VNT/VGT turbo. This would not be as finely variable as those turbos but more like a step across.
For interest:
http://www.supraforums.com/forum/showthread.php?742098-Kevin-s-Divided-Manifold-Quick-Spool-Valve
Thing is those turbos are $$$. This would be under $50 if you had a workshop to do it in. I did read that thread when I was looking at it. I will never need to do this but thought it was pretty interesting.
