what fluid?
Trent
Ok new to 6speeds im.putting 1 in on the weekend what fluid shud i be running in diff and gbox apprently my new gearbox is dccd . Car is a.track car.mainly but is road legal-ish.
Also who sells uprated shifter bushes for 6speeds cheers trent
 loner']
[quote name='soopersubaru said:
Motul Gear oil FF LSD 75W/90 for DCCD and LSD applications.
Use Motul Gear 300 75W90 with an open front diff.
Use that with any factory subaru front LSD equipped box as well.
The factory LSDs in the 6 speeds do not require any special LSD oils, as they are either viscous (suretrac) or helical, not plated (hence no need for an LSD specific oil - but you can still use it, I dount it would do any harm, apart from costing a bit more!)
 Tony']
Guess i should have stated..Plated type Lsd...The Dccd is a plated clutch mechanism however...Yep costs $4.00 a litre more. Tis fully synthetic...Reduced my fuel bill...another 800 metres/litre in my wagon. Good stuff ;)
