HELP!!! IDENTIFYING MY HEADS
Hey guys,
just wondering if anyone knows how to identify heads, i have a 1996 gf8 wrx.
my heads have under bucket shims, and two lines through cam shaft stampings, 1 line thru the middle and 1 line towards the end. the valve faces have EH and IH on them.
basically wanting to know what version they may be, (sti, standard, etc)
long story short, brought the vehicle, old owner had motor recond (bottom end) and had heads put on that he knows nothing about..
any help would be greatly appreciated.
cheers
boosted
 boostedwrx said:
hey guys,
cheers
boosted
photos of cams and rocker covers please :)
These heads look just the same in the camshaft area as mine,,,,,so my valves are older still huh?..sorry about lack of photos, i dont knw how to post them up lol, ive tried but its just not happening lols rocker covers are dead smooth on the outside,.. no ribbing on them or anything..hope this helps at all... cheers
i havn\'t seen these before, but its likely they are v4 sti due to:
shim under bucket = sti
V3 sti having different markings on the cams
96/97/98 twin turbo will have blocked off water/oil lines on the LHS head
anything newer than V4 has a different intake manifold bolt pattern
and that ben-jamminn has identical heads on his V4 sti :)
what do you mean about the valves?
Was just trying to work out if i had a "mongrel" head on my hands, if you knw what i mean,
Lyk a head with possibly different or wrong valves in it , or camshafts in wrong head set up, sucks ther is no part or id numbers on them to easily distinguish them apart,
i might just have to bite the bullet and keep these ones aside if i cannot work them out, Ive had a few subarus now but likewise ive never seen these heads before,ive even done a bg5 conversion with v2 sti heads and there nothin like this either :(,,,,,,,maybe easier to buy a set of sti heads that are genuine to their name off someone reputable.
As kamineko said, they are likely version 4 STi, do they work OK? if it ain\'t broke why fix it ;)
lol,
Think the last owner had engine rebuilt by monkeys, They forgot to put a shim under 1 exhaust valve, and didnt put valve keepers on properly on another, i have retrieved 1 shim from the sump but cannot find the other, so my guess is, its been overlooked at rebuild assembly stage >:(
does any one have some or know where i can order some,, subaru in taranaki seem to have no clue on finding the correct part for me :(
cheers boosted.
Yup i realise tht, and just waiting on new digital verniers to measure valve to inside buckt clearance , have measured cam to bucket allready,, jst need to add the two together and wullah, minus .25 clearance for exhaust, wld that b about right?.
Hi all, just updating progress on head job lols, all shims moved measured moved and re measured, all valve clearances within 0.02mm, altho i do have 1 exhaust valve at 0.33 wich i think is still to big :(
also,
if any one can help maybe, has anybody got a couple of shims i could buy, i need 1 @ 2.35mm and ill remeasure the other tommorro, and update again
My local subaru dealer cannot and will not supply shims for my heads without a vehicle vin code to match them >:(... grrr fustrating. Be ok if i actually had a genuine v4 sti lols,
till tomorro,
boosted, 8)
That 0.33 gap could cause an annoying Tick, at 0.08 oversized. While your doing it, with the rest within 0.02. Do it once, do it well ;)
Interested myself now, with heads off and Cam/Valve changes happening. ;D Will let you know if I find any Part Numbers. I\'m shim over bucket, but will be a start?
Your Subaru Dealer orders Shims by Vin Number, most parts are found with Vin (My OEM suspension Bushes were). He doesn\'t know the Vin for your Heads. Just get any V4 STI Vin to order Shims and tell him to just trust you ;)
