Help with VF30
Dvnt
ok so i stripped down vf30 took pics as i did it, have gone to reassemble several weeks later and pics on the camera got mysteriously been deleted and ive since had to move my work area so its not in any order laid out, ive googled and got info off various sites but some of it is incomplete or doesn\'t show what im after so does someone either have a vf30 sitting around they could strip down and catalogue or a definite parts books that can show how it goes back together?
ive put it back the way i thought but when i tighten the turbine nut it stops the turbines from spinning.
Thanks :-[
Vf30 is way diff, rebuilt mine recently. Some parts are the same,but parts 8,5,2 etc don\'t exist on the 30. Not too keen to pull it off again to strip. But yeah as above follow your nose. Unless you live in chch, I can\'t be much more help.
yeah vf30 a wee bit diff, there\'s 2 washers one silver one copper not sure i have them in the right place, and sadly in dunners bugger it ;D
Also on a side note, if it goes together, and is tight to spin, it\'s possible that the smaller copper washer isn\'t seated properly, the one in my kit was tight. I had to give it some tapping with a socket and hammer. Then all was swell from there
thanks for the link ive been using that one but it wasnt downloading the page properly so i was missing bits but your link is giving me all of it.
I had the silver and copper washer around the correct way so still not sure why its still tighening up, , ive tried the socket trick already but still no luck so im stumped
