gf8 v6 wrx turbo manual clutch pedal only half retracting
markw336
I have brought a 1999 gf8 wrx and noticed that the clutch pedal only retracts half way old owner told me he had recently put a new clutch i
Took it to a mechanic to instal a new slave cyl and a master kit and a good bleed and was sweet for a day then went back to half way retracting
Then i replaced the fork spring and it was better then it went crap agai
Got a rebleed was sweet then jumped in it ths morning and its doing it again
Question now is what do i do? Its not leaking anywhere only thing i can think is its geting air somehow or the new slave is sad
they are a pain to bleed correctly, thats for sure. had the cylinders been cleaned/honed?
anyway, just have a look at the slave: without removing the cylinder, peel back the rubber seal and see if its filled with fluid?
how many bleed points do you have? some clutches have another circuit that runs around the firewall just to dampen vibration
Clutch pedal arm is worn.out. the pin that goes through the hole that holds the master cyl to the clutch pedal arm slowly hones out that hole on the pedal arm and causes a notch for that pin to seat in so the pedal gets stuck on the notch on return because it can\'t pivot
