help with turbo failures
Hi there has someone started the blown turbo thread yet??? I have recently acquired a 2003 gt with a blown turbo, actually it has been through 4 within two months. I am looking at the cat up pipe, removing the banjo bolt and just recently I found out I have to check the ocv\'s. Has anyone else dealt with this problem? Any hints??? :-\
Check for blocks in the oil drain as well.
It should be pretty obvious what\'s killing them. If there\'s damage to the turbine wheel, the uppipe flexi or cat is self destructing. If the bearings are shagged, it\'s an oil feed problem.
