Sub and Amp question
ADIKT
I have an Earthquake ph2000w/d1.1 mono amp
RMS Power 1-Ohm: 1000
RMS Power 2-Ohm: 1000
RMS Power 4-Ohm: 500
I also have 2 pioneer 12" DVC subs 400wrms - 1400wmax (TSW309D4)
With a 4Ω dual voice coil, you can opt for a 2Ω or 8Ω set-up (provided that there is correct power matching between the sub and your amp)
I believe it is 2x 4Ω coils
How would I wire them up so the amp would see a 2Ω load?
Like this?
Are you sure they\'re dual 2?
TSW309D4 is a Dual 4 ohm sub. If you measure the DC resistance of a "4 ohm" coil with a multimeter you\'ll usually see something less than 4, more like 3.4
Mind you if you wire as per the diagram up top you won\'t do any harm if they\'re actually D4, you\'ll just get 4 ohms and not much power.
If the amp is 1-ohm stable, which it seems to be if it has rated power at 1 ohm, you may as well wire them down to 1 ohm and get twice as much power, if they are in fact D4\'s
Only issue is that if it\'s actually a D2 then you\'ll get 0.5 ohms and your amp will either go into protect or crispy-fry itself.
