Flickering light issue
Probably the 20 setting will do what you need.
Some kinda crappy multimeters measure Vac by rectifying half the wave, measuring the peak value in DC then doubling it. If yours does this then you'll see like 28v but I think most half-decent multimeters won't behave like this.
But it should show 0 AC regardless? Coz it showed 32 and 60 or something on either setting. Think it might be wreaking havoc because at low rpm cruise and idle car can run a bit hairy. A/F stays in check just won't hold a steady idle and feels slightly lumpy at cruise. I havent spent much time tweaking the idle maps but it with it also happening on cruise it makes me wonder.
A proper DMM will decouple the DC component and only read the AC ripple, which is what you want.
A cheapy uses a bit of a kludge to read AC, and will show some odd voltages when attached to a DC source.
Best way to tell is with an o-scope, pop down and see RAC with it, he will be able to tell you in 30 seconds with a scope.
