help all you sparkies!
subytrackhack
If you unplug the female plug on the starter motor and apply power to it from either bridging the power from solenoid wire or battery does it crank over? I've seen this before but on a bh5.. done engine swap on it a few years ago cos had run beb, the guy was stuck out in the westcoast and was cranking and cranking it after it broke to the point the starter motor burn't out aswell.. i swapped out the shorty for him but never did find the cause of the problem he was happy to take it as it was and find the issue himself, same issue had no power at starter on crank, the alarm was unlocking and locking but was most likely the problem, do what sparky said
from memory to program the uniden remotes you turn the ignition red lights on and off 10 or 15 times withing like 5or10 seconds till it goes "beep" and then hold down the 2 buttons on remote??
Not sure about reseting the alarm..
