help all you sparkies!
subytrackhack
hi 98 type r coupe
once i lowered the car the wheels rubbed through the airbag wires and brought the airbag light on which is ok.
so i got a aftermarket steering wheel and cut the wiring loom off the airbag ( with the battery disconnected.and also pulles the bulb out of the dashboard.
now the car has zero power only the head deck clock and door open light come on nothing else on the car works.
spliced the wires for airbag back together disnt work.
checked all the fuses inside cab and engine bay 3times
replaced the bulb
nothing makes sense can someone help me :)
Have you tried disconnecting the airbag control unit that will sit along the trans tunnel under the head unit? That may have a kind of immobilisor and then there is the other: when you cut the wires; arr you sure you didn't cut some vital stuff? It may have been other loom
Also; Pictures of what you cut and where, just in case it wasn't what you thought it was.
whoa that's a whole lot of fluff-ups right there
ABS wires maybe got worn thru by your tires
could have just unplugged your airbag and replaced steering wheel (one must assume this car is never going to get a wof ever agani anyway)
did you have dash out/plugged the ignition/key back together correctly?
[merged both threads, 2x same topic simply not necessary soz]
does starter get power?
cutting the
SRS wires should not do this [you already know this/duh]
might be time to find the back of the ignition (remove cowling) and see if the back of that is getting power
no worries mate .
ive tested back of ignition and that gets power.as does some of the dashboard.i dont get power at tge exciter wire on the starter .which makes me think maybe the ecu has.gone into shutdown or safe mode? or maybe the alarm ? when i go from on to start with the key the alarm is clicking..
