Zerosports Sequential Boost Controller Issue
steve118
 Andy_Mac said:
Would be pretty unlucky if that was the case. Don't know how you wired it up and if its easy or not but its probably worth unwiring it and seeing if its still goes fine with it removed.
Does it through a code/engine light when it goes into limp other than 65?
just taken it for another drive. this time i got up to 7000rpm but secondary turbo did not seem to kick in at all. and now the boost cuts on primary at like 4 psi. very frustrating. will look at the wiring again now
  • Replies 116
  • Created
  • Last Reply
Top Posters In This Topic
 Andy_Mac said:
Where you had both together was then car running or just on accessory? 33-speed sensor
51-neutral position
http://sl-i.net/FORUM/viewtopic.php?f=10&t=28362
started off with just keys in ON position, then i checked with engine on. no difference.
i just had another play just now and i noticed the secondary was working this time with controller off, but i still cant go past 10psi on either primary or secondary turbos
 Rosssub said:
Green to green. Black to black. Then turn ignition on.
Radiator fans should go full, all solenoids start pulsing, all secondary change over items open/close, BBOD starts breathing like Darth Vader.
did that, everything was making noises. and quite a noticeable ticking noise coming from around the intercooler area?
Long shot but are you sure its definately working and not just the primary slowing down in switchover and then coming back around higher up in the revs?. Not sure if it can do this without going into limp mode though.
So that noise near the tmic would be the intake valve for the secondary but the exhaust one might still not be ok. Don't suppose you ever come down to tauranga?
nah im sure it was secondary, the primary got to like 9 then around 4250 rpm secondary kicked in and i could feel it. and it was a lot harder than just primary.
any idea how long the drive is down to tga from auckland?
just tried it again with bonnet open. ticking noise i could hear is coming from front left guard. couldnt really tell if the ECV was moving or doing anything at all as the fans were so loud. but i drove it once again and secondary turbo comes on with controller off and doesnt come on with controller on
Should be able to see the shaft go in/out. Maybe need a small mirror.
Not sure on the internal wiring of the controller and whether it bypasses its own circuits when turned off or what but if all is well with it off then you would definately think its the controller. What is the secondary crossover point set to when on?
