Legacy questions
1994legacyrs
Just a two questions that I would like to find out more about.
First, what is the power split in the awd system. I have heard things like its 90-10, 70-30, 60-40, 50-50, but nothing conclusive. Also does it use a viscous limited slip differential?
I have done a bit of research and narrowed down that my car has either an ej20h or an ej20r ;)
I have looked at the engine bay of both and I can't spot any differences and I'm the man at 'Wheres Wally'. Anyone know - and what are the main differences?
Most autos use a wet clutch pack that sends power to the rear wheels. Giving a theoretical split of 90-10 up to 50-50 when the clutch pack fully locks.
VDC autos and some from Turbo Foresters and H6 Legacys use a VTD center diff which is geared to give a 35-65 split. It also has a wet clutch pack that can lock the diff to 50-50. Models with this transmission have a different shaped rear housing and no FWD fuse as the rear wheels can never be disconnected from the front, there is a solid link.
Most manual transmissions use a 50-50 torque split. Theres simply a limited slip diff of some description in the middle that locks up when the fronts or rears lose traction.
As far as i can tell DCCD Boxes use a system similar to that in the VTD autos except the driver can choose the power distribution from 35-65 to fully locked. (not certain on this one as ive never played with it)
