Single Pot Pad Change (Akebono Caliper)
After the other one went well, thought it try doing it again as I was changing the rear pads anyway!
What you need;
⦁ Set of Pads (obviously) TRW - GDB990, Bendix - DB1168
⦁ Jack
⦁ 12mm Spanner or Ratchet
Thats pretty much it for what I consider mandatory, but I'd recommend also having;
⦁ Jack Stands
⦁ A can of brake clean
⦁ Anti Seize
Next step is to get the car in the air. Use the jack stands if you have them. Safety is always good!
So hopefully this ones as useful as the other one. I also did one for the rear diff, but not sure if people would want that one :)
Again any suggestions are welcomed :D
Edited by Firenza
