Subaru Factory Alarm - How Good?
BLazeD
Any aftermarket alarm can be bypassed with a bit of wiring knowledge. The factory one can't. Its built into the engine ecu, the body control ecu and the dash cluster. You need a Select Monitor to access the alarm systems.
OK thanks. So just to confirm - I am better off leaving the current alarm in there as opposed to get an AVS S5 or something?
Hmmm, now these guys are saying the Subaru Factory alarms didn't even have immobilisers until 2005/2006...
http://www.legacygt.com/forums/showthread.php?t=115115
Subaru doesn't have an immobilizer until some 2005/2006 models. Besides for the money, you are better off going with something non oem.
But then....
http://www.legacygt.com/forums/showthread.php?t=1419
I'm surprised there isn't more commentary on the issue
People believe way too much of what they read on the net. When you pull the key out of the ignition if a key lamp starts doing single flashes on the dash you have an immobiliser. After you lock it with the remote on the key and it starts doing double flashes then you have an alarm too.
And when you get back in, the keylight will flash the number of times someone tried a door handle - at least thats what the manual for ours says.
