V7 STI blowing blue smoke, powerless - no boost, no Bov sound too
g4atenza@hotmail.com
Hi there,
I bought a v7 Sti and when I was driving it home and I blew something, as it lost boost and blew a lot of smoke. First thought was I blew the turbo and when I took the turbo off there was heaps of oil in the turbo and intercooler so I replaced the turbo with a VF30 that I bought off this forum and now its doing the same thing. No improvement at all, I'm hoping the turbo I got off this forum is also a faulty turbo because I don't want to think it's my engine as it was only replaced a few months ago.. Anyone know how I can diagnose the problem? I believe it idles fine and drives fine just really powerless, maximum boost is 9 psi and that's after a long time on the accelerator. Any help or advice is appreciated :)
Sounds dropped cylinder-y maybe, possibly, get a compression test done maybe?
Symptoms (of which you haven't given a heap) suggest maybe a holed piston / cracked ringland, or simply a fcked turbo
How do the plugs look, that will give you a quick indication on if you've munted something proper
Save yourself a lot of time and money and take it to a mechanic. Could be a number of different things, all of them expensive to fix I am betting...
so wasting money on things that are not the problem will make a **** situation worse.
Go to a mechanic
Random guesswork of most likely cause is excess knock has cracked or holed a piston or just destroyed the ringland (same thing more or less)
Either too much boost, a ****ty tune, running it on bad fuel, fuel pump giving up.... a dodgy injector who knows why it blew until someone actually diagnoses it
Until it's apart you won't know if it's fixable, damage may be unrepairable - but get it diagnosed by an expert first.
bugger man! that sounds like it will be a costly repair if you have no compression... just take it to a mechanic and get them to go over what could be the issue, what part of the country are you in and we could recommend a few places you could go to get a quote or even some advice
