Quick dumb amp Q
Marky
Once upon a time I was sitting a diploma in electronic engineering... It appears I have forgotten most of it, haha
I have acquired one of them classic old sony 444w 4 channel amps, I want to use it on my speakers for the hell of it (already have sub and can;t stand for things in my garage to be unused)
My headunit is semi budgo spec and does not have a front pre-out, so I'm using a line converter thing to give the amp an RCA input
Am I best to a) run all four speakers in 2 bridged pairs as just "front" speakers
or b) split that RCA signal to give the amp a front and rear input/output and have 4 normal outputs to the speakers, the head unit still giving "front" to speakers and "rear" to sub as before (so I can still do HP and LP filters through it happily)
...I think I've answered my own question while typing it out
I'd bet my bottom dollar you won't get a headunit with 3 x RCA outputs for less than $200, probably lucky to find one under $300 TBH.
How many speakers / sub are you wanting to run? The best arrangement would be 2 speakers of channels 1/2, and then bridge channels 3/4 for the sub.
So the headunit doesn't even have a single RCA output? That must be one very very very pov-spec headunit. I think even the cheapest ones I've ever seen have at least a single RCA for a rear / subwoofer output. If it does have that one RCA output, use that for the subwoofer
No no no
The head unit is half decent, bout $280ish? It's a Pioneer one with the bluetooths and things
It just only has a rear/sub RCA (because I didn't think to check for that), and I'm already using that for an existing sub & amp I have now. I just happen to have this 4 channel amp I'd also like to give a home
Is okay, I have already answered own question
I always found that searching through the Repco clearance section on the website was good for finding a decent HU at a discount price. Normally about half of retail.
But anyway, def go with separate channels for each.
I had the same amp about 12 years ago powering 2 6x9s and a sub. It got the job done.
