Upgrade???
Hey guys i have a 97wrx wagon, wantn to upgrade it as i got some yellow tips and orange sticker afm and bought a v4 sti 6s ecu from trademe, i wacked it all today but it wouldnt fire?? wanted to but just wouldnt quite go, is ther anything else i need to do to get this combination working??? i put all my old injectors AFM and ecu back in and it still wont go just pissn fuel out from somewhere??
i thought that to but crankn it over its pisses out fuel underneath but round the injectors are dry so somewhere it is leaking lol, just wondrn if ive split a pipe, but yellow tips and a orange AFM with a sti comp should work fine shouldnt they???
you have a fuel leak somewhere - gool luck finding it - you may have pinched a pipe putting your manifold back on..
and yes those mods should do you nicely - Be careful with the turbo you are running though - It should be a TD04, and it wont cope with high boost. anything over about 14psi.
Next mod wud be to go larger turbo - VF23, or VF22, maybe a 28, a few possibilties there. Do your research.
bg id say 96 sound right?? with the E orange airflow 90mm inlet roundabout and a 6S V4 sti comp, i can only take the guys word of trademe for that if it really is from a v4 sti, i put all that in and it was flooding itself fillin 1-2 with fuel,
Yep got a 04 at the mo but its bein exchanged for a vf23 n i got the yellows and the orange AFM for free so bought the comp, not to fussed buying a type R soon but would be nice to spice up the wrx before flickn it off
found where the fuel was coming from...the manifold it was dumping it into the manifold lol, but cleared all the cylinders and maniflod still wont start so gona see if its putting out any fault codes i guess take it from there,
hey guys i am new to the subaru scene so i have a 98 wrx wagon and if i did the same as UH-1H has done as in replace the injectors to yellow ones and change the sti comp as long as they are installed properly the car should start straight away with out any problems?
and also if i upgraded my factory wrx top mount intercooler to a sti top mount would it improve my performance?
is a STI typr R ECU better ot a STI ra ECU better for upgrade from a standard WRX ECU....?
thanks in advance for any help.........
haha found what was wrong just badly flooded gave it a push start the other day n she popped into life lol, just on the point of being to much fuel left in there even tho i drained it all so the yellows, comp and airflow should work now lol
  • 3 months later...
how did it all go in the end??
