Boost Gauge - Mechanical or Electrical?
El_Chado
i had a mechanical boost auto-meter gauge, was allgood, read 2psi high though. I switched it out for a Electronic defi BF system, wouldn't go back! has high boost warning, brightness settings and a record function + i have other defi gauges. But it was not cheap. Both types show your boost which is what you want to achieve, just depends on how deep your pockets are and if you want the flashy functions... i personally think the electronic gauge is more precise and fast + it doesn't require 1.5m of boost hose (which can delay readings?)
 El_Chado said:
Where do you connect an electronic gauge to? Super glue it to a vac line right? :P
electronic have a pressure sensor that mounts in the engine bay ( i put mine near the boost solenoid and t it into a valc line like a normal boost gauge) will come with a wire diagram, normally 4 wires i think.
